Build Thread! will keep adding Pics onto end Update5
Just order the pushrods for my build, finally ready to finish my stroker.
Ordered Manton 11/32 at 7.550. Those guys are great to work with.
Ed
Ed
LS3 short block stroked to 4.00 for 417 built by Erik Koneig HKE racing in TX. Wisesco Piston, Callies crank and rods. 11.1 to 1 compression. AFR 205 heads ported by Tony Mamo and opened for the bigger displacement. Cam by Geoff of EPS, Fast 92 ported by Vengence with a NM92 TB.
tune
I have Efi live my pcm has custom O/S 5 now and my headers collectors both have WBO2's but I will need a dyno.
Is your dyno have dynamic loading so that I can hold an engine at a certain rpm and load. I figure that the best way for a perfect speed density map (VE table).
Ed
Ed
Ed
Ed
We can certainly provide you with an excellent dyno experience. Our facility has everything you need, including a Mustang MD-500 that can load the vehicle anywhere you need it for as long as you need it. We have several shops that use it for boosted engines where load is crucial for a proper tune.
On a second note, those pushrods are awesome! We carry our own line of 3 pc pushrods as well. That's top notch stuff you have there!
cost
I got them not only because I loved the look but they had the best coil mount look with the type of coil being unique (he actually had me send him a photo of the type of coil I was going to use). confusing? he makes different brackets depending on whick coils your going with.
That alone was worth it to me, most vendors couldn't tell yea the difference between center or peripheral bolt covers let alone coils options!!!!!
If you noticed I have the truck coil with the the heat sinks.
