Finally have a working fuel indicator,installed sender & pump
I just removed the fuel sender and pump from my 87 TA. I didnt drop the tank, there was a butchered access panel in place so I took advantage if that. I am going to get a proper plate made to cover this area up. Immediately after installing everything, started the car up and it dropped to 1/2 a tank where it should be. One issue down, more to go.
Sorry posted this in the Camaro forum, should be the Firebird one...can it be moved?
