question for 317 heads
ive heard of people milling these down to make higher compression. how much could u mill them? could u say make them about like a set of 243's? ive heard 317's flow just about as well as a 243 so can i just mill them down and if so will i have to get shorter bolts or anything
LS1Tech Premium Sponsor
Like Pwebbz8 said, you can mill them down to almost as small a chamber as the LS6's came with without having to worry about intake alignment and such, but then you have decreased your valve drop (piston to valve clearance therein) to the point that you cannot run a very aggressive camshaft at all.
LS6 heads would be a much better starting point for an NA/nitrous combo!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
