What wires are to neutral safety switch in a4 6 pin harness
Old 07-24-2011, 11:50 AM
skeeter99's Avatar
Default What wires are to neutral safety switch in a4 6 pin harness
Im trying to bypass my neutral safety switch and the stickey does not indicate what two wires (colors) that i need to run together or ground
Old 07-24-2011, 12:05 PM
skeeter99's Avatar
alright got it figured out its the purple w/ white stripe and dark green wire run together and car starts thanks for yalls help
Old 03-26-2013, 02:34 PM
dreww's Avatar
Do you just tap in a jumper wire? Or must you completely sever the connectons to the PN switch for those lines and run them together
Quick Reply: What wires are to neutral safety switch in a4 6 pin harness
