LS2 throttle body for C5Z?
The LS2 TB will not bolt up to the LS6 intake. It will bolt up to the LS2 intake (not recommended as they don't flow well) or the Fast 102 (the older 90/92 will also accept it). You will need a harness to adapt the electronics as well.
If you don't want to buy the overpriced conversion harness you can wire it yourself using the plug that goes on the LS2 TB. As mentioned you can't put this on an LS1/6 intake. I would recommend porting it if you intend to put on the LS2 TB...lots of material to be removed in front of the blade.
^^ What Red99TA said. You more then likely won't notice any difference porting your TB alone, except for better throttle response. Without swapping intakes, a decent bet is to port both your TB and LS6 intake together. It's cheap (around $330) and flows close to a FAST 78, with a good port job.
OH! If you're pro-charging, porting the TB isn't going to matter. Trust me. You'll get throttle response, but you won't see HP gains. The blower forces as much air in as it can per stroke of the crank. While ported heads (and MAYBE a ported intake) will help, the difference between a ported and non-ported TB is going to be so small, it will pretty much be a waste of money unless all you're looking for is throttle response.
Some of my friends have told me they "feel" the gain, but the SOTP gain is throttle response only.
