which skinnies fit over cts-v brakes?
hey guys im wanting to go with a drag setup but wondering if anyone has the cts-v brakes what skinnies they're running to clear the fronts. also pics would help alot! thanks guys
love that look bro! thanks for the input! could you give me some specs on your wheels and tires? offset, wheel size front and rear, and tire sizes. thats the exact setup i was actually planing on running the ccw drag pack...
No problem, but unfortunately I have no offset specs. I bought them from a local Vette owner.
The fronts are a 17 x 4 and the rears are 16 x 10. I do have to run a 3/8 spacer on the rear and nothing on the fronts. I also have the fenders rolled and bump stops moved in the rear.
Tire wise I have M&H 185/55R 17s, the rears are 315/45R 16.
great! thanks for the pics. this will for sure help out. are you lowered much in the rear? im curious because when the rear end drops down on a hard launch if the inside of the tire will touch anything or because of the bump stop relocation everything is like factory? sorry if these questions seem repetative.
