Can someone give me some fan settings for an E38 with a 160 stat?
Moderator
I like to run my low speed fan at just below pivot temp (like what you see
at decent rolling speed, low load) and the high speed fan turns on 4 degrees
higher, off at 2 degrees higher.
Did what I mentioned before leaving work work and the car ran between 176* and 192* the whole ride home... seems good, could even bump up temps a bit?
Thanks for the input Jimmy but I think the E38 tables are different... I will try to pull up my old SS tune and look.
