Paging Nashville Tennessee
This is my first time living in Nashville TN
What should i do to pass emissions ?
What do they look for ?
I have a PROCHARGER Big Cam and it’s loud as Hell / full exhaust though
what do they scan for on your computer ?
2002 chevy 1500
lsx 427 black label heads
96 lb injectors
snow performance
MSD coils
procharger F1A 27 lbs
fast 102
comp cams
turbo 400 ATI 4000 stall
9 in moser 390
315 Nittos rear
2002 chevy 1500
96 lb injectors
snow performance
MSD coils
fast 102
comp cams
9 in moser 390
315 Nittos rear
Last edited by Untamed2000; 08-05-2011 at 06:05 AM. Reason: if someone wanted to know what i had for a vehicle
Depends on which *** you get you must have full exhaust, and all they check your computer for is to make sure you dont have any codes thrown or check engine light...and then hope your big cam isn't letting to much emissions fly out lol
They will check you exhaust, cats, fuel cap and filler neck, and a sniff test good luck with a big cam with overlap it will be tough to get it to pass. I went through with my truck (stock Dodge Ram) a few days ago and they just did a scan through the OBD port no sniff test this is the first time they have not sniffed my vehicle not sure when they started that or what the cut off is year wise for not doing the sniff test.
