really considering going FI with procharger..
other wise looking at a kit you are gonna want an 8 rib kit. It will require getting an ATI balance
And by the way listen Blue00ZZleeper he has helped me with a lot of my questions.
Everything i need is..
- ATI balancer
- 8-rib pulley
- D1SC Kit (Reverse Rotation)
- 60# Injectors? (brand?)
- Racetronix fuel pump w/ hotwire?
- Twin intercooler setup w/ plumbing
- Tune
also, what pulleys create what PSI? and would 7psi be enough? If say, 10psi is max on a stock bottom, id like to stay under that, so im not too sure what psi to go with.
I read somewhere that for every pound of boost you have a 6.8% increase in horsepower of what the motor is makin. So if im making 383rwhp, and if i ran 7psi, id gain 47.6% hp increase which would b 565rwhp in theory.
- ATI balancer
- 8-rib pulley
- Tune
First on the racetronix pump, from what I've been told a racetronix pump with a hotwire kit will support 550whp. Though I've also been told you have a greater chance of leaning out at that level also. Besides you won't be saving $800 it'll be more like $400. Racetronix pump a wire harness is $200 and you still have to buy injectors. The lonnies twin intank is $600 plus injectors.
Now to make an 8-rib setup you need more than just a pulley.
-8rib blower pulley
-8rib crank pulley
-ati harmonic balancer
-and if you're piecing the entire kit together you can just order the j bracket for an 8 rib setup so that it'll come with the correct stand offs, idler pulley, spacers, and hardware. If you get a used j bracket from a 6 rib setup all the hardware pieces will need to be changed for an 8rib drive.
Hope this helps, I'm sure other guys will chime in. If I missed something please correct me. I'm no expert by any means, but guys around here have been very helpful. Always keep alert for procharger threads or even just search the topic. A lot can be learned from others trials and tribulations. Good luck!!!
https://ls1tech.com/forums/forced-in...ore-boost.html
https://ls1tech.com/forums/forced-in...rger-guys.html
I would suggest going over kill on the fuel system. Leaning out isn't something you want to play with. I had a dual GS340 pump setup wired into the stock fuel pump wiring and it worked just fine until I went to a return style. 60 lb/hr Siemens decka or motron are the most common. Keep a eye in the for sale section as they come up often but sell just as quick. Bob from brute speed will have most of the parts you'll need at the best price. Don't forget gauges as well. At a minimum you want fuel pressure and a wide band as they will save your ***...ask me how I know this lol. I made 10psi with a 7.25" crank pulley and a 3.70" blower pulley. For math's sake alone I was spinning the blower to 52,219 rpm at 6500 engine rpm. Your going to lose a little more boost with your cam specs but it should still pull nicely up top...its not optimal but you'd be surprised at a prochargers performance with a big cam. I would start with the 7.65" crank and a 4.0" blower pulley and see where that gets you. You'll be spinning the blower to 50,968 rpm. Feel free to send me a PM with questions...I'll help as much as I can.
also, would 10psi b too much?
I'm a little confused on your math in comparing FI to nitrous. Your blower build will cost you at least $5K and you are looking to add a little over 100 rwhp to get to 500. A 125 N2O kit, with all the bells & whistles will cost you $1K or so and achieve your power goals. $4K buys a lot of nitrous, especially for a street car that sees few races.
