Procharger guys
Ill start.....
lq4/317 headed motor, 224/230 in.567 ex.578 on a 114 LSA blower cam
low mount tensioner so i dont need to run the pully sandwiched inbetween the j-bracket..
I haven't taken any pics since I redid all my intercooler plumbing. I will get some soon as things will be changing again.
Also I see you are running a vic jr intake can I see some pics of how the fuel rails are mounted to the intake. I am wondering if I can reuse my rails I have now or if I need different ones.
Not bashing at all, I personally like all forms of boost such as, roots, centri, and turbo. Again taubr, been following your build thread for awhile, glad to see it's coming together. Should be a badass ride. What kind of power are you expecting out of it?
)They both have there pro's and con's. It just seems to me that I see people get way in over there heads on turbo setups and then get frustrated with FI in genral. The ProCharger kit is such an easy bolt on that most anyone can do it.
Gotta admit that the turbos make great power, ill do one just a soon a I win the lottery
Im in the process of ordering all my stuff for my new heads and intake and my 3.1 pulley for the d1 i have....afr 225's, vic jr setup, meth, and maxing my little d1 out.
Everthing else is done on the car besides weight reductions and intalling my last suspention part(anti roll bar) other then that i will be all set to scream on the streets!!
Keep the pictures and stuff coming guys im interested in everyones setup also
Here is the dyno graph from a CTS-V we built, we started with a new LS2 block, used a Callies 4.0 stoke crankshaft, our EPP blower cam, off the shelf AFR 225 heads, FAST 92 intake, Kooks 1-7/8 headers, and a ProCharger F-1A. Bob
Thats why i went with the procharger!
