4l60e marks?
Well new information. not about the marks but the separator plate. Apparently the separator plate had a check ball stuck in it. IDK if that made it not shift into 3/4 but IDK if it can be fixed.
I was wondering if the TransGo plates are any good? better than GM?
The trans go plates are a good replacement for the factory plates. And yes, a plate with a check ball stuck in the feed hole will cause extremely poor shift quality... if it doesn't smoke the clutches or band before it actually completes the shift.
g
g
