is my pump failing due to heat?
Looks like my car has ran fine for to long... runs great for the first 20 min or so and still runs fine when cruzing, if i get into boost after it's been running for a while it will cut out and not go much over 5k. I've had the same condition before once it was to large of plug gap, the other was a slipping belt. new belt and bosch supers gapped at .030. a single 255lph pump with 50lb delphi injectors, delphi opti with 5k miles on it I've got a set of tr6's (thats what i've ran for a couple years) the tr6's seemed to not idle as good. It's always something...
