Trans Solenoid Issue?
2004 GTO, a4 is having transmission issues. I'm not sure if it's the solenoid or the 3/4 clutch pack. Under light throttle it shifts 1-2, and when it goes into 3rd it just revs, however, under heavier throttle, it revs in 3rd, once you let off the throttle it seems to engage 3rd gear. Trans fluid level is good, fluid condition is bright red, and doesn't smell burnt. Any insight into the issue would be helpful. Circle D Stall and B&M trans cooler was installed about 2k miles ago. Also if I'm correct this is a 4L65e right?
