01 Camaro SS(9",FLT Trans,EPS Cam,Suspension, EFI Live)
Year: 2001
Make: Chevrolet
Model: Camaro
Price: $9000
Mileage: 107000
Private or Dealer Listing: Private Listing
Location (State): IN
Color: Blue
Transmission: Automatic
Drivetrain: Rear Wheel Drive
For Sale…2001 Camaro SS in Navy Blue Metallic. This car is set up for drag racing but can be street legal easily. I have a lot of money invested in quality parts. The engine is a stock bottom end LS1 (107k miles) with an EPS Cam (Intake Duration: 234/246 @.602 .607 111LSA) and Stock 799(243) heads. The heads have been cleaned up and trued with Patriot Gold spring kit and Trick Flow pushrods, GM head bolts, MLS head gasket, LS7 lifters and LS2 timing chain. The engine has had Full Synthetic Castrol oil and K&N or GM oil filter since I’ve owned it (80K miles). Car also has LP 1 ¾” stainless headers with stainless y pipe and Magnaflow cat back exhaust, under drive pulley, 42 lb injectors GM 85mm MAF, LS6 Intake, FTP 98mm air lid, Custom Ram Air, Racetronix Fuel System, Ported Throttle Body, HSW Wet Plate Nitrous Kit with Micro Edge controller, Innovate Wide Band 02 and display, PCV catch can, EFI Live V2 with serial for wideband and 2 credits left.
Transmisson is a FLT stage 4 4l60e with a deeper pan, Sonnex 2nd gear servo, BM trans cooler, and a Circle D billet lock up converter with a 3200rpm stall (free re stall), poly mount and BMR cross member with Torque arm relocation.
Suspension has Strange Coilovers up front with Hypercoil 2.5” linear rate springs set up for drag racing and Spohn solid motor mounts. Rear Suspension starts off with a Moser 9” with 31 spline axles with a Strange Ultra light spool, BMR boxed frame connectors, BMR chromoly adjustable torque arm, BMR Drag Bar, Spohn adjustable chromoly lower control arms, Spohn adjustable pan hard bar and Comp Engineering Drag shocks.
Wheels and tires are Weld Pro Stars with skinny street tires up front and Mickey Thompson ET Drag 28x10.5x15.
I have removed a lot of stock parts for weight reduction. I have all the stock parts except the HVAC box and carpet. Also I have a set of chrome SS wheels that started to flake that go with the car. The car DOES have a Salvage title. It was hit in the front end and I bought it after. The hood was replaced with a Factory SS hood and the whole car was checked for straightness and repainted 3 years ago. The car has a few chips in the paint here and there. It’s not a show car but still looks good. The car has about 15 passes on it since I owned it. I have timeslips from last year before I put the cam and heads on. I have always had a conservative tune in the car. The correct plugs and AFR has been maintained while using the NO2.
Asking price is 9K. Offers welcome but don't insult me. No trades! Name is Justin. PM me for phone number.
