Fitting for power brakes part number 12559760
I remember seeing the question asked a few times and while going through some old pictures I found a picture and part number for the fitting that goes into the truck manifold for vacuum for power brakes when the intake originally had a plug for hydroboost brakes. Maybe somone can put this somewhere it will be easy to find??
Are you talking the part that fits in that same hole to plug it?
If I was in a bind I would just use a small hose off the fitting I listed and a bolt or ? to plug it. I am kind of **** myself and would want the correct plug. Must be easy to find at a junk yard? I may have mine somewhere but I plan to someday go to hydroboost and will want that same plug?
THANK YOU for sharing this information, this is the part I'm looking for right now.
Glenn
