Injectors
Old 08-10-2011, 07:51 PM
bBody22's Avatar
Default Injectors
Im new to EFI and i was wondering how do i go about taking off a injector on the LT1 i didn't wanna mess anything up by just doing anything
Thanks in advance for the help
Old 08-10-2011, 07:55 PM
94fixerTA's Avatar
Unbolt the fuel rail and carefully lift up. They also each have a small clip on them. I found it easier to lift the whole rail and slide them off.
Old 08-10-2011, 07:57 PM
bBody22's Avatar
thanks im about to go try it now
Old 08-10-2011, 08:03 PM
pillarpod's Avatar
i just used a flat head screw driver and popped the clip off
Old 08-10-2011, 08:09 PM
bBody22's Avatar
is it just the 4 bolts on the top that i take out?
Old 08-10-2011, 08:11 PM
bBody22's Avatar
the top of the injector seems like its hitting the rail, so how did you go about doing that
Old 08-10-2011, 08:21 PM
bBody22's Avatar
i have the rail up but its still stuck in the rail how do i get it out without breaking it
Old 08-10-2011, 08:40 PM
defaultexistence's Avatar
Why are u removing an injector anyhow?
Old 08-10-2011, 08:43 PM
bBody22's Avatar
because it has a slite miss and i have change everything you can think of so im thinking its one of the injectors
Old 08-10-2011, 08:54 PM
Where's the face palm ?? What are the plugs gapped at? What have u replaced?
Old 08-10-2011, 08:56 PM
bBody22's Avatar
Explain please
Old 08-10-2011, 09:02 PM
http://en.m.wikipedia.org/wiki/Facepalm
Old 08-10-2011, 09:20 PM
pillarpod's Avatar
its missing, so is this where your starting at, the injector?
Old 08-10-2011, 09:26 PM
Eeehhhyep.....
RamAir95TA's Avatar
If the car is missing, the first thing I would do is call the police.
Old 08-10-2011, 09:39 PM
! JOE DOES have a sense of humor! Good one , thanks for the laugh!
What are the plugs? What gap? What parts have you thrown at it ?
Old 08-10-2011, 10:24 PM
the_merv's Avatar
Lol...is it missing at idle?
Old 08-10-2011, 10:46 PM
Puck's Avatar
Lol.
A slight miss is usually ignition related, not fuel, which is why you will get a lot of questions about plugs, gap measurement, opti miles, coil, ICM, etc.
Old 08-11-2011, 05:58 AM
bBody22's Avatar
[QUOTE=defaultexistence;15258565] ! JOE DOES have a sense of humor! Good one , thanks for the laugh!
What are the plugs? What gap? What parts have you thrown at it ?[/QUOTE
new fuel pump,fuel filter,opti spark,coil,air filter, spark plugs which are black now form it domping from fuel into the motor. and i was thinking it was a injector because it was just smoking on the left side.
when im driving it goes to bucking and it isn't running clear and every now and again when it get on in the gas it trys to clear up but you can tell the power still isn't there. also when i stump it it just rolls smoke out of the left tail pipe
Old 08-11-2011, 06:30 AM
pillarpod's Avatar
i just choked on my cereal
Quick Reply: Injectors
