Injectors
Old Aug 10, 2011 | 07:51 PM
bBody22's Avatar
Default Injectors
Im new to EFI and i was wondering how do i go about taking off a injector on the LT1 i didn't wanna mess anything up by just doing anything
Thanks in advance for the help
Old Aug 10, 2011 | 07:55 PM
94fixerTA's Avatar
Unbolt the fuel rail and carefully lift up. They also each have a small clip on them. I found it easier to lift the whole rail and slide them off.
Old Aug 10, 2011 | 07:57 PM
bBody22's Avatar
thanks im about to go try it now
Old Aug 10, 2011 | 08:03 PM
pillarpod's Avatar
i just used a flat head screw driver and popped the clip off
Old Aug 10, 2011 | 08:09 PM
bBody22's Avatar
is it just the 4 bolts on the top that i take out?
Old Aug 10, 2011 | 08:11 PM
bBody22's Avatar
the top of the injector seems like its hitting the rail, so how did you go about doing that
Old Aug 10, 2011 | 08:21 PM
bBody22's Avatar
i have the rail up but its still stuck in the rail how do i get it out without breaking it
Old Aug 10, 2011 | 08:40 PM
defaultexistence's Avatar
Why are u removing an injector anyhow?
Old Aug 10, 2011 | 08:43 PM
bBody22's Avatar
because it has a slite miss and i have change everything you can think of so im thinking its one of the injectors
Old Aug 10, 2011 | 08:54 PM
Where's the face palm ?? What are the plugs gapped at? What have u replaced?
Old Aug 10, 2011 | 08:56 PM
bBody22's Avatar
Explain please
Old Aug 10, 2011 | 09:02 PM
http://en.m.wikipedia.org/wiki/Facepalm
Old Aug 10, 2011 | 09:20 PM
pillarpod's Avatar
its missing, so is this where your starting at, the injector?
Old Aug 10, 2011 | 09:26 PM
Eeehhhyep.....
RamAir95TA's Avatar
If the car is missing, the first thing I would do is call the police.
Old Aug 10, 2011 | 09:39 PM
! JOE DOES have a sense of humor! Good one , thanks for the laugh!
What are the plugs? What gap? What parts have you thrown at it ?
Old Aug 10, 2011 | 10:24 PM
the_merv's Avatar
Veteran: Air Force
Lol...is it missing at idle?
Old Aug 10, 2011 | 10:46 PM
Puck's Avatar
Lol.
A slight miss is usually ignition related, not fuel, which is why you will get a lot of questions about plugs, gap measurement, opti miles, coil, ICM, etc.
Old Aug 11, 2011 | 05:58 AM
bBody22's Avatar
[QUOTE=defaultexistence;15258565] ! JOE DOES have a sense of humor! Good one , thanks for the laugh!
What are the plugs? What gap? What parts have you thrown at it ?[/QUOTE
new fuel pump,fuel filter,opti spark,coil,air filter, spark plugs which are black now form it domping from fuel into the motor. and i was thinking it was a injector because it was just smoking on the left side.
when im driving it goes to bucking and it isn't running clear and every now and again when it get on in the gas it trys to clear up but you can tell the power still isn't there. also when i stump it it just rolls smoke out of the left tail pipe
Old Aug 11, 2011 | 06:30 AM
pillarpod's Avatar
i just choked on my cereal
