help on cam and heads
Old 08-11-2011, 12:34 PM
pimpin78transams's Avatar
Default help on cam and heads
Ok guys I have an ls1 with an a4. Mods are ls6 intake, p&p stock tb,fipk,lt headers, off road y, magnaflow muffler, and a tune by frost. I am looking to upgrade my cam and maybe heads but I do not want to sacrifice too much mpg cuz its my dd and gets about 55 miles a day. I understand I will have to sacrifice some gas mileage but I want as much power as I can get and not spend a fortune on gas. So what size cam would yall recommend and also what heads. I would like to try to get into the 11s in the 1/4. Thanks
Old 08-11-2011, 12:57 PM
5.0 LsX's Avatar
243's, custom cam...
Old 08-11-2011, 01:38 PM
Frost's Avatar
It needs a stall BEFORE it gets a cam swap.
Old 08-11-2011, 04:13 PM
supersick99z's Avatar
Agreed.
Old 08-11-2011, 04:18 PM
KTK Z28's Avatar
Your probably going to want to look into getting a small torque converter if you are considering getting a cam. You should talk to a forum sponsor and see what they can cook up for you as far as a H/C combo goes. Your likely going to end up with a nice set of heads and a small cam if you are set on keeping the stock TC... getting into the 11s with a stock converter is definitely going to be a chore.
Old 08-11-2011, 04:48 PM
Sorry I didn't mention that but I do plan on putting a tc in. Maybe yall can recommend one also
Old 08-14-2011, 11:29 AM
ttt!!
Old 08-14-2011, 01:06 PM
TeeWX's Avatar
Caring about fuel mileage and power output at the same time usually doesn't turn out so good. Like trying to build a car for autox and drag at the same time. Good luck! Especially on an A4.
As for Heads/Cam. I know above 243's were mentioned. If you want "243's" your going to have to get them used. If you want brand new heads that are exactly the same as a 243, look into 799's. That's what I bought for my build.
For the Cam. I would stay between 220-230 duration and if you want it friendly on mileage go with 114lsa+.
Old 08-14-2011, 05:43 PM
PREDATOR-Z's Avatar
226/232 .609/.604 112+2 LSA, stall a Yank SS3600
