main bolts?
Old Jul 26, 2011 | 10:18 PM
ronnjonn's Avatar
Default main bolts?
I tossed my originals, believing they were as non-re-use-able as the head bolts. But now I can't find any replacements. I found the ARPs, but I don't want those. My bearings and crank look excellent, so no need for a line hone.
Old Jul 26, 2011 | 11:37 PM
z99ls1's Avatar
Restricted User
They are tty bolts, so you definetly can't reuse them. I did a quick search and can't find any, but they have to be out there
Old Jul 27, 2011 | 12:03 AM
z28241's Avatar
Why not use ARP's? well respected name in the business..
Old Jul 27, 2011 | 01:02 PM
RARON455's Avatar
Buy the arp studs,, much better and the last ones you will have to buy. If you want gm prolly have to go to the stealership.
Old Jul 27, 2011 | 02:30 PM
Smalltime's Avatar
I read that they where not TTY. I re used mine and have had no issues.
Old Jul 31, 2011 | 09:44 PM
MattSapp95_T/A's Avatar
a LOT of guys reuse theirs with no issues at all...
ARPs are nice but you will need a line hone if installing them.....
I have my stock ones if you need them
Old Jul 31, 2011 | 10:59 PM
JS01's Avatar
Call up Scoggin Dickey they can get them I'm fairly certain.
Old Aug 1, 2011 | 11:04 AM
Beau@SDPC
LS1Tech Sponsor
Hit him up he will take care of you!
Old Aug 1, 2011 | 02:01 PM
Smalltime's Avatar
If I just had my LQ9 built. Would I still have to have it line honed???
Old Aug 1, 2011 | 02:54 PM
Bilster's Avatar
You shouldn't have to line hone for ARP bolts but you should definetly line hone for the studs. When you tighten a main stud or a main bolt there is a certain amount of distortion on the cap generated from the action. Studs pull differently than bolts so the distortion on the main caps is different.
Old Aug 1, 2011 | 03:08 PM
Smalltime's Avatar
So anybody know where I can get ARP main bolts all I can find is the Studs
Old Aug 1, 2011 | 03:32 PM
I have never heard of ARP main bolts.... Only studs... And you need a line hone I you use them for the reason listed above
Old Aug 1, 2011 | 03:55 PM
ronnjonn's Avatar
Originally Posted by MattSapp95_T/A
Beau@SDPC
LS1Tech Sponsor
Thank you.
Old Aug 1, 2011 | 07:38 PM
S10xGN's Avatar
You 'may' need a line hone, however, it is NOT etched in stone. I have converted several engines from bolts to studs without needing a line hone. It just depends, put the crank in and torque the studs. If you can spin the crank over easily with little resistance, you're good to go.
Old Aug 2, 2011 | 06:04 PM
Bilster's Avatar
Not going to deny that I've used this method before but what exactly is "little resistance". Best method is to torque the studs to the recommended torque without the crank or bearings. Then check the main bearing bore with a bore guage. It doesn't take much to be out of the factory specifications. That range is 2.750" to 2.751". I would say that if you are not willing to do at least this check, just use new factory torque to yield bolts, save a few dollars over the ARPs and rest easy. If your going to go through the expense of adding ARPs, your planning on running your engine hard. Then at least take the time to install them right. The following is right out of the ARP instructions in the box of studs:
FOOTNOTE: When changing from factory fasteners to high strength fasteners, clamping force and tolerances will
change, therefore it will be necessary to check the main bearing bores for proper size and out of round condition after
installation of the studs and align hone the cylinder block if necessary. The main bores should always be align honed
using the same fasteners and lubricant which will be installed during final engine assembly at the recommended preload.
Old Aug 2, 2011 | 08:59 PM
S10xGN's Avatar
Checking the mains goes without saying, I have (and use) a full set of mic's, snap gauges, and a dial bore gauge. My last "stud conversion" was a Buick turbo motor, even with the mains set at 0.002, the crank spun over 4 or 5 turns by hand with the studs fully torqued to 110#. If I don't see "free and easy" rotation, I stop and find out why.
Old Aug 8, 2011 | 04:45 PM
ronnjonn's Avatar
PM sent
Old Aug 8, 2011 | 05:44 PM
Paul Bell's Avatar
That's MISTER MODERATOR
GM numbers:
LS1 main bolts: 12560272, singles
LS1 main bolts with stud for windage tray: 12560273, singles
LS1 main bolts through block side: 12556127, 5 pack
Old Aug 8, 2011 | 06:54 PM
KCS's Avatar
KCS
Moderator
That is not good advice. Just because it spins freely does not mean the bearing geometry isn't completely ruined.
Old Aug 8, 2011 | 07:41 PM
I concur
