Rear seal impossible to get off, new one not the same.
Is it me or is the rubber seal supposed to just come right out in one piece? Must be the origional cause it's coming out piece by piece. Don't know what to do at this point.
And from the looks of things the new seal on the right doesn't even look the same. Note the top left. Pulled that spring out from the old seal. Does it go back in the new or no? Getting frustrated.........
Your old seal is apparently dry rotted. Just scrape/pry it all out. You don't reuse anything from the old seal. The p/n of your seal is the 97 version. The 93-96 seal is 10088158. The RMS housing is a different p/n for 97, as well. Why/how they are different, IDK.
I just read through a few searches that said the teflon seal from Felpro leaks. Greeeeaaaat.
Oh did I mention that I broke the lower left bolt too. Lucky it didn't break in the block. Took me 20 minutes to get it out. 35 ft-lbs my ***. Either the manual is wrong or the bolt was so damn fatigued after almost 20 years. Welp, off to Ace again in the morning.
I'm just ******* winning like Charlie Sheen with this build.
BINGO!!
My LT1 is a '96, I've owned it since October of '95. I store the car for the winter, but start it up 2-3 times over the winter. Nonetheless, I've developed a rear main leak twice, over the years, possibly due to the lack of daily usage keeping the seal oiled. I have replaced the rear main seal both times. I now have the teflon seal, with no issues.
^ This did not work worth a SH*T. The sleeve made the install WAY too tight, and the sleeve broke. Then, I tried again with the broken sleeve (this would allow the sleeve to stretch more to get over the crank). Got it on, but the sleeve was too far in (lost inside). Had to pull it again and remove the sleeve, and just carefully, mindfully installed the housing w/seal over the crank. It's not hard to do without the plastic sleeve or a tool, you just have to be careful.
Village Troll
The sleeve really isn't made to go over the crank journal. Just, more or less butt up against it for a smooth transition between sleeve to crank. I used the sleeve and it went on easily.
One thing you guys need to be aware of. Comparatively speaking, the rubber seal will tolerate a little more "abuse" during the installation, without leaking afterward. The teflon seal, however, is far more "fragile".
Therefore, the plastic sleeve is in place to allow you, the installer, to slide the seal successfully over any roughness that might be present on the exposed portion of the crank, outside of the seal itself, without damaging the seal.
This is basically a similar situation to the water pump drive shaft seal, where you need to get the WP seal successfully over the splines, without damaging it.....
