Mezeir wp??? Rebuildable?
Old 08-14-2011, 08:11 AM
HioSSilver's Avatar
Default Mezeir wp??? Rebuildable?
Anyone have any idea how long they last? I've been running on on my dd for 5- 6yrs . Now when I get into it it wants to heat up.
Old 08-14-2011, 08:18 AM
DaFireMan's Avatar
yes they last pretty long. and if they go out they are rebuildable. it cost about $150 if u pay for the shipping
Old 08-14-2011, 09:27 AM
HioSSilver's Avatar
Cool..thanks for the quick reply. I'll be calling them mon. Hopefully they can turn it around quickly.
Old 08-14-2011, 09:55 AM
That's MISTER MODERATOR
Paul Bell's Avatar
They should be able to sell you the rebuild parts. Bearings, seals, impeller, motor brushes.
Old 08-14-2011, 11:28 AM
HioSSilver's Avatar
Awsome. Has anyone ever had one just slow down? I have noticed the car running a little warmer this summer, mainly when it's 90+ with the ac on. I've made laps on a road coarse and never had this issue. Temp guage has never moved on a 1/4 run, I've hot lapped the **** out of this thing at the dragstrip.
Old 08-14-2011, 10:26 PM
Randy WS6's Avatar
You may want to check your alternator to see if it putting out enough amps mine was doing the something and it was the alternator was going bad. The factory alt. is not fond of aftermarket power add on. Just a thought ..
Old 08-16-2011, 10:59 PM
DaFireMan's Avatar
This is true, now that i think about it the alternator did go bad on the car at the same time as the car started to run a little warmer. **** that may have helped to kill the electric pump. I WOULD STILL RECOMMEND A REBUILD THOU, TURNAROUND WAS EXTRA FAST WITH THEM, GOOD PEOPLE.
Old 08-18-2011, 07:11 AM
Black 99 Bird's Avatar
How much was it?
Old 08-18-2011, 07:34 AM
HioSSilver's Avatar
I talked to Mezeire yesterday. They said a rebuild is $250 and turnaround is about 2 days. They also said their pumps run on 7-8 volts pretty good and usually they work or they stop working, they don't slow down. He told me to look at my radiator. I have and atleast the part you see looks good. I have made some airflow changes in the front but at normal speeds it is fine.
