4l80e duel feeding the direct drum
For high hp applications is it a must to do this mod , and also can it be done ,
With the transgo hd2 kit already installed ?
I'm curious as to why you would ask this question. Do you have a -2 kit installed in your 80e already... or are you trying to plan an upgrade to your existing 80e?
In the past I have seen guys take a 60e hd-2 kit and just make the valve body / hydraulic mods but not remove the transmission and modify the rotating assembly. That usually is not a very good idea.
g
g
Hi G , I have the transgo hd2 kit installed already in the trans. It been running ,for about 30,000 k. At 1000rwhp . I have stripped the box due to lock up in reverse, and found a broken rear planet set , due to lube issues. I think I have addressed, but locking at the direct frictions they are the worst. I've heard about this mod in the 400s and I hear that they do it for the 4l80e.
I'm only asking for expert advice . In Australia this box is not a common unit.
most hard parts I have to source from Us. Hope this answers your q.
the centre support feed orifice , and ditch the transgo plate.
