Door Panel Inserts
Door Panel Inserts
Ive got the door panels pulled off to do window motors, so I decided to do the door panels while theyre off. I had two questions about it. First how do you remove the board from the plastic clips on the inside of the door? The second question is does anyone put any type of padding down between the board and the vinyl? If so, what should I use? Thanks for the help.
