New LS1 Owners - Newbie Tech - A Duh Question.. Help me out!
Z28Venom
03-03-2004, 11:38 PM
Alright.. if the pipe from the muffler to the exhaust tip is 2.5", then what size does the inlet to the exhaust tip need to be?
I'm a bit confused. Should the tip slide into the pipe and then get sealed with a band clamp, or should it just meet flush with the end of the tip and the get sealed..
Thanks
Robzilla
03-04-2004, 12:00 AM
not sure what your trying to ask, but the part you put the tip should be the same size as your tip, and then the tip slides over the exhaust pipe and then clamped down or welded on
Z28Venom
03-04-2004, 12:25 AM
Thanks,
I just wanted to know if the tip was supposed to slide over the pipe exiting the muffler.
SoloSport
03-04-2004, 11:24 AM
I've got a 3inch Y-Pipe that goes into my 2.5 inch SLP Loudmouth
D2REngineering
03-06-2004, 02:59 PM
You probably put your tips on already but...the exhaust tip is supposed to slide OVER the existing exhaust pipe. The idea for it sliding over is not to disturb the airflow coming out of your exhaust. If you placed it inside your existing pipe, you will be disrupting this smooth air flow.
Z28Venom
03-07-2004, 03:49 AM
Thanks for the explanation. I haven't installed the tips yet.. I'm actually still waiting for the Rumbler to arrive from TSP... It should be here on Wed. :gruffy:
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
