another msd window switch thread
ok I have the MSD distributorless window switch part number 89561
Here is my problem. I have it all wired up white wire to the tach signal etc. there is a single grey "loop" wire. i have cut. With the wire cut the window switch does not work at all... when i reconnect the wires the window switch will work but it activates and deactivates at exactly half of what the pills are set at,
from what i read by cutting the loop it should bring the switch to work properly the v8 motor and it work correctly but it obviously is not.
