1999 camaro pcm pinout issue
Old 08-26-2011, 05:38 PM
jamiesls1's Avatar
Default 1999 camaro pcm pinout issue
I am confused what the pink wire number 19 on the blue connector goes to... It says ignition positive volatge. I am wondering if this goes to the fuel pressure sensor in the fuel tank because it calls for ignition feed ( I am guessing thats ignition pos. volt. )... and that 19 pink wire is the only positive voltage iginition wire on the pcm. Please help.
Old 08-26-2011, 09:35 PM
LS1MCSS's Avatar
Here ya go.
Old 08-26-2011, 10:13 PM
jamiesls1's Avatar
Thank you, and would you also happen to maybe have a diagram of the air pump wiring goes from pcm to relay to air pump?
Old 08-28-2011, 03:53 PM
shoemike's Avatar
Old 08-29-2011, 04:53 PM
jamiesls1's Avatar
Thank you shoemike.
Quick Reply: 1999 camaro pcm pinout issue
