3800 stall on a 3600 tune?
Old 08-27-2011, 05:09 PM
a-low's Avatar
Default 3800 stall on a 3600 tune?
When i was putting the car together i sent my pcm to frost for
a stall tune for a 3600 but went with a 3800. Now am i leaving
performance on the table or should i expect my trans to go out?
Is 200 rpm really a difference? Ive only put about 100 miles on
It since installed.
Old 08-27-2011, 05:32 PM
01ssreda4's Avatar
It should be fine....
Old 08-27-2011, 06:05 PM
Camarosteve44's Avatar
It should be fine, the difference is so minimal. However, still check with the tuner just ask him
Old 08-27-2011, 07:59 PM
dannyz's Avatar
LS1Tech 10 Year
Well, I went from a stock stall to a 3000 on the factory tune, then recently put in an FLT lv4 with an SS3600 stall. Trans is still running the factory tune, but I did adjust the shift points with my Predator. N/A it was fine, but it would tap the rev limiter on the 2-3 shift when using nitrous.
Old 08-28-2011, 08:53 AM
Circle-D's Avatar
I would think it will be close enough. You will know if it needs a tweak, hitting rev limiters on a shift.
Chris
Old 08-28-2011, 02:28 PM
a-low's Avatar
No doesnt hit the rev limiter if anything since the stall if feels like it idles a bit lower in gear
Like if im pulling out ftom the driveway give it gas then let go of it quick it stumbles.
Old 08-28-2011, 06:44 PM
dannyz's Avatar
LS1Tech 10 Year
Thats normal. The stall is smaller in size / weight, so has a bit less inertia to keep the ole' engine spinning during instances like you describe.
Old 08-28-2011, 07:18 PM
a-low's Avatar
Ahh gotcha!
