How do I clean my block
Soi want to clean my short block. Its on a stands btw
What do I use and how with out getting debree
In between the pistons and the walls
There's a Simple Green that's made for Aluminum works really good, the normal Simple Green or Purple Power will pit up and or stain aluminum.
You can get the aluminum safe Simple Green at most airports.
I like this idea too Gil. You want some kind of non abrasive cleaner, dish soap is used since it is good at cutting through grease and not really harsh. The important thing is to let it dry out and then lube it so that everything does not get dried out and messed up.
