Is an 05 LS2 and 02+ LS6 cam the same?
ls6 and ls2 cams have same specs. but i dont think they are interchangeable, one has 3 bolts the other doesnt. also the LS2 has different knock sensor or position sensor as well. if you are going thru the trouble just pick a slightly larger or better performing cam. ls2 or ls6 cam isnt worth the trouble.
