Lq9 408 Belt Re-Routing Properly???
So i need somebody to refresh my memory, but if i'm just going to be running a alternator and crank only i need a bmr alternator relocation kit right??? I deleted the a/c compressor, smog pump, meizere electric pump and power steering so i'm trying to figure out what i need to do to unbolt the pulley from the water pump an just run the alternator and crank only on the motor. I wasn't sure if anybody ran the pulley system with a comp cams tensioner, water pump pulley, alternator, and crank??? If anybody has pics on this and any feed back it would help me out alot for sure because the motor should be back together next weekend...
