SELL FAST INTAKE or KEEP IT
I just ordered a LG G5XB camshaft to replace my n/a cam since i am going with a supercharger for my 2002 C5Z. I already have a 92mm FAST intake and a LS2 TB on the car. Should i keep the FAST intake/TB or switch back to a LS6 intake/tb? Some say the FAST leaks, cracks, etc under boost. What is the psi limit for the FAST? Is there a limit or is it just any amount of psi? Or is the 92mm FAST okay under boost? My G5XB should be here this week and i will be starting my cam swap. SOOOO i would like to make my mind up on the FAST intake before i get the cams swapped out and need to pay for the retune lol. SELL or KEEP?
thanks guys. I am still not sure about what to do lol. Plus it is hard selling a part that is so new for cheap. BUT for my build an LS6 intake would be more than enough since i am not looking for max numbers. I would like to hear from some ppl or even vendors about their exp with a 92mm FAST with FI. I have seen a few post about the 102mm FAST but i thought i read it is made stronger.
Here is a good article to check out, they test results of cam + intake in N/A form and with boost. http://www.gmhightechperformance.com...est/index.html
What about porting the FAST/TB? I know it helps with n/a builds so i know it should make a diff in supercharged application. Yes it is a lot of money for the amount of rwhp/rwtq but if i keep why not lol. Unless the porting would make the intake weaker. From what i have read/been told the LS2 TB responds well to porting (throttle response). Thanks
fast units are way thicker than OEM pieces, they even weigh 3 pounds more and thats alot for plastic. so they will hold up longer.
the storys you hear of them blowing up are from detanation under boost and nitrouse, but i rather the intake be the giving point than have a metal intake and have detonation that blows up the whole motor.
92mm fast/ls2 tb made 5 rwhp/3 rwtq more than the ls6 intake/stock tb on my car on the same dyno/tuner as before. This was after the car was tuned for the fast intake. N/a results and sae/dynojet
