Is a 150 ok?
Is a 150 ok?
I got a 2000 camaro cam only. Its got stock 28 pound injectors and a 255 pump. Ive got a nitrous outlet plate kit on the way. Just wondering if a 150 shot would be alright on those injectors? If not what shot would be alright?
If you spray the 150 shot are you planning on getting it tuned for the nitrous. I see you are cam only and I've got a pretty good idea that the tuner raised the timing some to make more hp plus most if not all cams have timing ground into them. It may be a good idea to get some sort of device to pull timing when you want to spray it or just have your tuner give your ride a "nitrous tune"
