GT55 Turbo & Cooling Issues!
I have been piecing my turbo kit together over the past couple of years. Finally got it out for a drive down the highway and back to my shop. The coolant temps slowly went up to around 220 and climbing by the time I pulled into my driveway (10 minute drive). I can start the car up and it idles up to about 180 with the fans and does not move until I start driving it. Details on setup below:
GT55 Turbo
CR5 Blocked 430Ci
LS6 Ported heads
dual row cross flow radiator w/16" fan shroud 22.50 x 19 core
stock water pump
E85
no thermostat
I have not trimmed the front bumper yet but will if need be. The radiator and 6" thick intercooler are sandwiched together and I think that is the problem. Should I space the intercooler away from the radiator say 6 inches or so? Will the stock water pump be OK? Here are some pictures below, just looking for some suggestions.
GT55 Turbo
CR5 Blocked 430Ci
LS6 Ported heads
stock water pump
E85
no thermostat
Thanks for all the replies guys! I have come across a pretty good solution, found one of these at the local speed shop.It has a built in thermostat circuit with it also.
I will gain enough room with the remote water pump block adapters for a turbo blanket that will keep under hood temps down even more:
Going to try to incorporate the front bumper support I made a few years back to space the intercooler. Hopefully this should solve my cooling issues:
I am open to any comments and suggestions, posting up as many pics I a can for reference. Thanks!
Radiator Welded Up
Welded up the water pump flange and -16an fittings to the new griffen radiator tonight! Getting closer, now just need to space the intercooler a little. This radiator is the same core size just uses 1 1/4 tubes and now I have two 10inch fans instead of one big one.
the truth is that due to that you cannot move the water too fast
but the is a reason that few ppl that remove there thermostats on a ls1 tend to run hot, that is because there is a crossover between the inlet and outlet of the waterpump that set directly behind the t-stat and the t-stat has a valve built in to cover it
so if you have removed your t-stat you need to get a freeze plug and plug the crossover hole
but i must repeat you absolutely cannot have "too much water flow"
LS1Tech Co-Founder
I like the idea of running a thermostat too, even just a 160F.
If you look one some of the big dog cars, they are running radiator caps that high-mounted, I talked to Mike Brown about this five years ago but honestly I don't remember what he said. I'm assuming it works better maybe gets all the air out?
ok Mr. math formula! i think we are talking about two different things. however good luck with your formula.
I use that same pump! with the Moroso remote thermostat, seems to be working for me.
where does the hose on the coolant crossover tubes go? I don't see a spot for it on your radiator. My hose got clogged once and had overheating issues on the racecar...
