Dirty Dingo motor mounts for A body swap, thoughts? Also have accsry question
Old 09-12-2011, 05:40 PM
Mr.Bu's Avatar
Default Dirty Dingo motor mounts for A body swap, thoughts? Also have accsry question
Has anyone used these for a 68-71 Abody swap? If so, would you recomend them?
http://dirtydingo.com/store/American...bflrfivf4clib4
Also, I have an LQ4 shortblock with L92 heads with truck crank pulley and water pump, that's it. No idler, no alt bracket etc. I've also got a carb intake so tb clearance isn't an issue. I'm not running a/c or a power steering pump, should I just run the smokinhawk alt. setup??? I've read the alt. hits frame with the F-body setup. Suggestions welcome!!
Old 09-12-2011, 10:02 PM
jerhofer's Avatar
I used them in my F-Body 2nd gen and was very pleased with the fit and the quality.
https://ls1tech.com/forums/chevrolet...77-camaro.html
Old 09-12-2011, 11:31 PM
chuckd71's Avatar
They are okay but ultimately not a must-have. The main parts look good but so far two of the bolts that came with mine have broken. That being the case I doubt I'll use them again for my next swap.
Old 09-13-2011, 12:12 AM
slownova73's Avatar
i bought the same ones for my nova, i mocked them up with the block and everything seemed fine.
Old 09-15-2011, 06:39 PM
1975delta88's Avatar
I used them for my 70 Monte and they seemed to work better than the BRP mounts I had originally. These mounts allowed me to push the engine closer to the firewall, BRP mounts didn't.
Old 09-15-2011, 06:53 PM
jerhofer's Avatar
My son has the BRP mounts on his '79 Camino. They fit well. With the urethane bushings on the BRP mounts, he feels he is getting more vibration from the motor than he expected. One of the reasons I chose the Dirty Dingo adapters was that I could use the factory motor mounts with the rubber bushings.
Quick Reply: Dirty Dingo motor mounts for A body swap, thoughts? Also have accsry question
