Clutch Shimming Made EASY with NEW Tick Performance Slave Cylinder Shim Kit - 3 Pack!
Old 09-13-2011, 12:25 PM
LS1TECH Sponsor
Joey@Tick's Avatar
Thumbs up Clutch Shimming Made EASY with NEW Tick Performance Slave Cylinder Shim Kit - 3 Pack!
Any of you who have installed a clutch into a newer GM vehicle have likely heard of (and measured for) a shim that can go behind the slave cylinder to ensure proper bearing travel (and thus, clutch disengagement). You may have seen our popular thread: https://ls1tech.com/forums/manual-tr...need-shim.html
I'm proud to announce that Tick Performance is now making the use of shims even more precise by offering THREE difference thicknesses:Since there is no way to tell which shim you'll need before measuring, it's a smart idea to keep a few on hand prior to install so you're not held up in shipping if you need one. For this reason, we offer a discounted 3 Pack:All are in stock and ready to ship. Make sure that you measure to see if a shim is needed during your next clutch install - you'll be glad you did! For more information on the measuring process, click any of the links in this thread.
While you're at our site, take a look around! We offer thousands of products and FREE SHIPPING on any order over $100! We look forward to doing business with you.
Old 09-13-2011, 01:41 PM
Formula383's Avatar
Nice! Good job!
Old 09-13-2011, 01:59 PM
chon79's Avatar
Shims are not needed for Monster stage 3 clutch correct?
Old 09-13-2011, 02:24 PM
LS1TECH Sponsor
Joey@Tick's Avatar
Manufacturing tolerances vary, not only with clutch setups but with your stock components, as well. No matter how high quality the clutch is, the only 100% safe bet is to measure when installing ANY brand.
Old 09-14-2011, 06:32 PM
2kblackgtp's Avatar
Great ! In the middle of my clutch install a few years ago I found that the shim I had was too thick and had to mill it down, this would have been helpful.
Old 09-16-2011, 02:58 PM
LS1TECH Sponsor
Joey@Tick's Avatar
Absolutely!
Thank you guys for the orders thusfar.
Old 10-07-2011, 08:51 AM
LS1TECH Sponsor
Joey@Tick's Avatar
TTT guys
Quick Reply: Clutch Shimming Made EASY with NEW Tick Performance Slave Cylinder Shim Kit - 3 Pack!
