? for TH400 guys
? for TH400 guys
What kind of revs are you running on the street? and with what stall/rear gears.
I'm still debating between a TH400, T56, or new TKO...
It's such a pain...the TH400 is definately what I *should* get for my future setup... But my favorite tracks (Englishtown & Maple Grove) are a good 200-250 mile drive away)...go figure...
But I figure with the manuals I'll eat clutches... So the cost could get excessive over time...
27" tall tires, PT4200 converter, 3.70 gear = 3000 rpm at 60mph. If I could get the lockup to work (I have a lockup TH350) that would knock off a couple hundred RPM. 200 miles at 3000 rpm is a long ride after being used to a M6 in one of these cars
I fixed it the easy way, bought a trailer and I will tow it to the 200 mile away tracks - way cheaper then converting it back to a M6
Very Loose TK4000+ stall, 4.10 gears, 28 inch tires. It takes some getting used to with the loose stall. The car will feel a little sluggish at low rpms, but once you kick it in the guts its all go.
The transbrake alone made the swap worth while. For a daily driver I would recommend a little less stall, and a bit tighter converter. My car was never a daily driver, so I went really big on the tranny/stall combo.
Yeah, this won't be my daily driver either- but I don't want to beat the hell out of the motor on those trips either. Maybe I'll just save for a GV overdrive in the future...
So 28" wheels fit without rubbing?
The Bull
I run a 4000 stall Neal Chance converter. With the stock tires and 3.73 gears the car winds out at 3000 RPM for about 65/70. I've done a couple hundred miles in it at a time and you just have to get used to having it wind out. The only thing you can't do is rocket down the highway like I used to be able to with the 6 speed.
28" Tires do fit on the right rims. Some massaging of the interior fender well is required to keep it from rubbing.
That's "massaging" as in smacking the **** out of the inner fender with a 3lbs hammer. I just beat mine a little bit more because I moved up to an ET Street 28 X 12.5, which has a little wider section (12.5) then my Hoosier 28 X 10.5 drag slicks (11.2). I may air grind my bumpstop mounts off and try to move up to a 28 X 13.5 someday.
My final verdict on the TH400 is that it's fine for short trips and cruising as long as you have a big tranny cooler (I run a 28K GVW) and don't plan on running cross country at 100+ mph. Obviously for drag racing, its a ***** out tranny that will dominate other cars with similar mods and no transbrake.
There are calculators to figure out what the revs would be.. just use 1 for the final gear ratio.
www.tciauto.com
www.tciauto.com
Aram- I've used them but didn't know what to put in for slip so it wasn't being very accurate. I figured best way to find out- would just be to find out from others.
I drive mine a lot......4000 stall, 3.73 gear.......mostly around town, I made highway trips to the track before, but I'm not gonna do that w/the new motor/blower setup.....
Its not bad cruising at 3K when you have the radio turned up really loud......
TH400 with Gear vendors
Without gear vendors I was running appro 3500 at 65mph with 3.73 gears and appro 26 tall tires. With the gear vendors and a swap to 3.55 gears (performed both at same time), now I run appro 2600 rpm at 65mph (this is with a 3500 stall). I might try a lower stall (2400) to get a bit more streetablility. With approx 500 ft. lbs or torque, my 3500 stalls more like 4000 and the 2400 should stall more like 3000, go figure.
