? for TH400 guys
But I figure with the manuals I'll eat clutches... So the cost could get excessive over time...
I fixed it the easy way, bought a trailer and I will tow it to the 200 mile away tracks - way cheaper then converting it back to a M6
The transbrake alone made the swap worth while. For a daily driver I would recommend a little less stall, and a bit tighter converter. My car was never a daily driver, so I went really big on the tranny/stall combo.
So 28" wheels fit without rubbing?
28" Tires do fit on the right rims. Some massaging of the interior fender well is required to keep it from rubbing.
My final verdict on the TH400 is that it's fine for short trips and cruising as long as you have a big tranny cooler (I run a 28K GVW) and don't plan on running cross country at 100+ mph. Obviously for drag racing, its a ***** out tranny that will dominate other cars with similar mods and no transbrake.
www.tciauto.com
Its not bad cruising at 3K when you have the radio turned up really loud......
