Intake manifold pressure
Old 09-14-2011, 09:13 PM
BrownBoy's Avatar
Default Intake manifold pressure
Hey guys,
This doesn't have to particularly be on an LS1, but any idea where I could find out the average suction pressure generated by automotive engines? I'm trying to find out the pressure of the air entering the intake manifold. I assume it would be a function of the engine's displacement and RPM but I can't find much by searching online.
Any help would be greatly appreciated, thanks!
Old 09-14-2011, 09:16 PM
99ws6ls1's Avatar
a vacuum gauge...
Old 09-14-2011, 09:24 PM
BrownBoy's Avatar
Great idea! Unfortunately, I don't have access to a running vehicle who's owner is willing to let me poke a hole in their manifold for a test.
Old 09-15-2011, 01:08 AM
bluess57's Avatar
For an LS1 you can use EFILive/HPTuners and read the MAP (Manifold Air Pressure) value
Old 09-15-2011, 08:03 AM
BrownBoy's Avatar
Do you know anywhere these graphs might be available or anyone who would have these graphs for me to look at?
Old 09-15-2011, 10:14 AM
joecar's Avatar
At idle, MAP is 35kPa (with stock cam).
At WOT, MAP is 100kPa.
MAP is a function of throttle blade angle and the engines compression ratio/ability.
Old 09-15-2011, 10:18 AM
LS1-450's Avatar
Don't know where there are charts, but, can tell you that @ idle the LS 5.7L MAP is anywhere from 20-60 kPa (near 40 kPa avg.) vacuum up to 92-105 kPa @ WOT. This is dependent upon VE, which is based on several variables.
Just that Joecar had posted when mine displayed. So, mine is redundant.
Old 09-15-2011, 06:26 PM
BrownBoy's Avatar
Thanks for that information guys, it's much appreciated!
If anyone else has some input and/or graphs, that would help me out a LOT!
Old 09-15-2011, 06:52 PM
ZeeOSix's Avatar
If you're working on a specific LSx engine and want to check its "vacuum heath", then just hook a vacuum gauge up to the high vacuum port that the PCV line connects to (located just behind the throttle body on passenger's side).
Old 09-15-2011, 06:55 PM
ZeeOSix's Avatar
Your numbers must be absolute pressure ... if so, then 40 kPa is more vacuum than 105 kPa. It's all in the terminology.
Old 09-15-2011, 07:23 PM
JS01's Avatar
The readings can vary greatly depending on what the weather is like that day, altitude and how restrictive the intake tract is. A multitude of things influence what the baro is inside an intake. Ideally you would want the 'vacuum' to equal '0' or be equivalent to the atmosphere at WOT (on a naturally aspirated engine at least). At part throttle/low load anywhere from 30-70kPa would seem fairly "normal" for these engines in my experience.
Old 09-15-2011, 09:09 PM
LS1-450's Avatar
No ****. That's why I went back & was removing the word vacuum from the post. Had incorrectly stated it twice. Was distracted while reviewing the post when I saw that joecar had posted. Typed the comment stating the redundant post & forgot that one. Knew that someone would waist time pickin' @ it.
Old 09-15-2011, 10:03 PM
ZeeOSix's Avatar
Oh well ... that's what being technical is all about.
Quick Reply: Intake manifold pressure
