what air pressure to run with m/t sportsman fronts 26.7.5 15 lt
Old 09-18-2011, 09:01 AM
meatyz's Avatar
Default what air pressure to run with m/t sportsman fronts 26.7.5 15 lt
i been running 32-35 pounds it says max 60lbs whats everyone running in these?
Old 09-18-2011, 10:56 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I've got 40 in mine
Old 09-18-2011, 07:50 PM
meatyz's Avatar
Originally Posted by Z28/2002
I've got 40 in mine
thanks ill pump em up alittle more
Old 11-18-2011, 05:33 PM
BrianSF-GA's Avatar
Are you on bias-ply or S/R Sportsman's? I am seriously considering these in front of an ET Drag .... If bias-ply, how do you like them? Did you go with M/T's recommendation of the 8-ply for a 3,000#+ car?
Old 11-19-2011, 03:09 PM
pancho toco loco's Avatar
At the the track I always pump the front tire pressure way up 45-50.
Old 11-19-2011, 09:31 PM
OIF1VET's Avatar
I ran my 26x6x15 SR's at 40 psi....
Old 11-20-2011, 01:18 PM
cody161's Avatar
The more that is in them the less rolling resistance there will be. I run 60 lbs in mine. I know some guys that race superstock, run et fronts, and they run 50-60 in them too.
Quick Reply: what air pressure to run with m/t sportsman fronts 26.7.5 15 lt
