high pitch noise from rear suspension
Old 03-07-2004, 06:17 PM
00NBMCamaro's Avatar
Default high pitch noise from rear suspension
when driving down any road no matter how smooth and come to joint in the road the rear makes a high pitched squeek. im thinking bushings on sway bar.. but i greased them and tightened them and still did the same thing.. bushings and sways are stock.. anyone else have any ideas
Old 08-25-2006, 04:56 PM
CaptUSA's Avatar
I've got the same problem. Any guru takers?
Thanks.
Old 08-26-2006, 01:10 AM
ultraz's Avatar
i think its gonna be either that or the rear hatch shock struts. Some people have greased them and used the little rubber adjusters for the hatch and fixed the problems
Old 08-29-2006, 06:49 PM
CaptUSA's Avatar
Yeah, I've tried that. No luck there.
Thanks for trying though.
Old 08-31-2006, 12:17 PM
Just an FYI Mine turned out to be the anti squeel clips that hold the brake pads secure. Got a rear brake rebuild kit and replaced the clips and silence ensued. Thankfully
Old 09-01-2006, 02:25 AM
CaptUSA's Avatar
Really?? I'll have to check on that. Thanks!!
Quick Reply: high pitch noise from rear suspension
