LCA Install
LCA Install
Going to install some LCA's , Relocation Brackets, and PHB. What is the best way to install. Any tips or tricks I should know. Any help is appreciated
Restricted User
Screw the saw idea lol. I might be doing my install tommarow morning of my new lca's and lca relocation brackets. Go to umi or bmr and look at there install pics on there site. Pretty much shows it all there.
now im confused, you have to grind parts for relocation brackets to fit??
As far as the LCAs go, make sure you dont tighten the bolts if the rear axle is hanging mid-air. lift your car from the rear axle when your gonna tighten everything down. The same with the panhardbar.
The install went easier than I had expected. And yes I used a grinder also. Really tighten up the whole car and got rid of the clunking noise I had. Thanks for all the input
Restricted User
LS1Tech Premium Sponsor
For any future reference you guys/gals will need: http://www.bmrsuspension.com/siteart/install/CAB002.pdf
Install isn't bad and I actually enjoy cutting some of the stuff on these cars...I don't know why? haha
