Need a clutch for my 8.1l to viper t56
I'm in the last stages of mating up a 2001 GM 8.1l to a 2001 viper t56. I have
changed over the viper front bearing plate and input shaft to gm and got a fly wheel for one peace rear main seal. Now I need a good clutch nothing to wild mabe in the 425-450 range. Heard that the GM Corvette clutch is the best bet but having a hard time getting info on what year is best and will work. Also sort of need a part # as most gm parts people can't seem to find a part with out a vin#. Also not sure about pilot bearing have a gm pilot bearing and was told gm only has the one so it must be it. Any info would be a great help and the right info would be super.
p.s. The alignement pins on the fly wheel I have don't line up with a core clutch I have but the bolt holes do and the clutch dosen't move once all the bolts are in can you run with out the pins
