Replacing Alternator find years of crud to clean
Swapping out the factory '98 alternator with the bigger KG3 145 amp unit. Get the front end jacked up and slide in the jack stands. During and especially after pulling the stock unit out I am greeted with years worth of thick sludge and grim build-up from the power steering unit. I believe in doing things right, so I've been cleaning this crap up for hours while laying on my back. Even pulled the alt. bracket assembly out to get at all the crud.
Maybe one day a mod or upgrade project will actually go smoothly without any side work involved......if this is even possible.
<End Rant>
<End Rant>
Im Totally degreasing the underside of my car while the motor, tranny and rearend is out. ive got everything separated. I have gone through almost a full pale of purple power and im still not done.
I'm pretty sure the leak had actually been pushing through the reservoir cap from over-filling by the previous owner. That has been corrected, so I'm confident it is no longer leaking. I did find two areas of coolant seepage on the water pump, so that will be coming out soon.
