Beck vs. Ported Fast 102 (408, tf 235's)
Whats up fellas, im bout to start a new motor build, lme 408, tf 235 heads...just looking for an intake choice now, for an NA build that will evenually be sprayed a little, should i go with the beck sheetmetal intake or a port matched fast 102 ??
This is easy, its truely all about combination. Money has zero to do with your choice, they shouldnt ever even be compared if you do your research. If you havent done the research......
Drive it on the streets at all = FAST
Drag RACE ONLY (leave line at 5000+ RPM) = Beck/sheet metal
Edit: Reading your sig, you absolutly have to have the FAST, the sheet metal intake would not only slow down your car, but make it feel soogy loosing 40lbft, like sheet metal intakes do by design to make power at 7000+RPM.
