What TH400 year or style do I need?
I'm looking to swap my t-56 for a TH400 trans. the plan is to find a used 400 cheap and bring it to my trans shop after I cut the bell housing off and install an ultrabell. then they can build it for the power i'll be making. what year or specific style of TH400 do i need to search for that will work for my camaro? are the bellhousing bolts the same as my t-56? or will i need a special ultrabell to fit an LS1?
i 'm just looking for a used th400 that i can cut the case myself. we just did one for my buddies malibu. it wasnt that bad. i'm still not sure what year TH400 i'd need to fit my car? id' assume something from an old camaro or chevelle? maybe and early 70's? i'm not sure how to tell them apart if there are differnces.
OP... what sort of power are you anticipating on making? A TH400 can take a punishment in stock trim.
g
