62 n 62 Nova L94 AFM DOD 6 Speed Auto
62 nova wagon with a 6.2 L94 VVT AFM DOD 6 speed auto with power 4 wheel disc brakes 9in ford posi custom front frame with rack streering 62 with harness being setup a/c mock up with belt
mock up motor these heads are for sale 799 new take offs camaro front stuts camaro disc brakes 9in ford being cut
trans hitting
motor was back and hitting in bellhousing moved up and forward now its hitting in the rear 6 speeds are bigger in the rear new tunnel is in, drive shaft is now hitting in rear area from lowering the car its all worked out, have new pic soon,starting on roll cage this weekend full cage hidden from sides front to back hope to have one sleeper on a wagon thanks for looking mike
ip install
lost track of time doing it but it was about 6 hours,left my camara at home so i could not take pic of fabbing it but going to make a nother one, had to cut dash a bottom where nut plates go and at top center to clear the two gages at the top of cluster thanks mike
