Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
How big is the cam in your ls1?
Old 10-16-2011, 11:24 AM
Uneverknow's Avatar
Default How big is the cam in your ls1?
I have the stock cam in my car still. I'm looking to do h/c/i this winter looking to see what everyone else is running. 90% street my thoughts so far are ls6 intake,prc stage 2.5 heads, 231/237 duration 617/602 lift 112lsa. Any suggestions are appreciated thanks
Old 10-16-2011, 11:26 AM
t5munoz's Avatar
228/228 .588 .588 114 lsa
Old 10-16-2011, 11:31 AM
Cosmos's Avatar
I would gget a bigger stall with that cam.
Ive had a TR230 111LSA, 236/232 110-1 LSA, F13 228/234 112+4LSA and the TRex 110LSA. The trex makes the most power but the fun street factor of the other 3 cant be beat. The first three made power from 2.5k and pulled to 6.4 no problem. The TRex makes great power and pulls crazy at higher speeds but sucks below 4k even with 59cc heads and 4.30 gears.
If I was going to pick any of those cams again it would be the FM13, best combo of all of them.
No surging, makes power early and pulls to 6.7k.
Hope that helps.
Old 10-16-2011, 01:12 PM
Turd Gen Guy
1nasty86's Avatar
230/238 in my ls2... makes nice power
Old 10-16-2011, 01:16 PM
xX-Z28-Xx's Avatar
What's the lift on the FM13?
Old 10-16-2011, 08:59 PM
Uneverknow's Avatar
My car is a 6speed car if that changes anything. What kind of numbers are you putting out with that set up
Hope that helps.
Old 10-17-2011, 07:08 AM
Cosmos's Avatar
I put down 416 on a mustang dyno with a ls1 intake
Old 10-17-2011, 09:01 AM
JohnnyBz28's Avatar
My cam is the Patriot Performance cam
225/229 .581/.591 114+4 LSA
It's not a bad starter cam but really do wish I went bigger. Through my 6 speed and 12 bolt I put down 412/390.
Old 10-17-2011, 09:31 AM
Captain Double Post
BOBS99SS's Avatar
ms4, if your on the street alot i would advise you to go something alot smaller,i also have a m6, if you race alot its a great cam and loves spray , but there are soooooo many better cams out these days, i would say eps custom grind, you can get all you want out of a cam, i m going to swap my cam come spring since i drive it alot more than i thought i would, i will be going with eps hands down , im shocked on how well all there cams have done in test,and at the track
Old 10-18-2011, 08:39 PM
T AM's Avatar
I'm running the Torquer v3 from TSP. It's a 231/234 .643/.598 on a 111 lsa. I love the cam. Not too big; not too small, imo. It also should work well with my future plans, which may or may not include a 100 shot.
Old 10-19-2011, 06:58 PM
Uneverknow's Avatar
Thanks for all of your opinions, it something I'll have to look more into now that I have some real world feed back
Old 10-19-2011, 07:05 PM
msydow's Avatar
MS4 here in my 383 ls1. just put a torquer V3 in my buddies six speed. it made like 416 or something with only full exhaust, cam, and tune. did a TSP Tsunami in my other buddies auto. it made 42X through a circle d and full exhaust.
Quick Reply: How big is the cam in your ls1?
