transmission mount (m6) help!
Old 10-17-2011, 02:15 PM
Alex2210's Avatar
Default transmission mount (m6) help!
ok so yesterday i replace my heavly cracked energy suspension transmission mount with an anchor transmission mount . when i removed the jack i noticed the stick was sitting lower than normal... was i supposed to buy a spacer? but i continued to get a hit from the transmission when i hit a bump or vibration when i hit 70 , what is the problem
Old 10-17-2011, 02:20 PM
escosaint's Avatar
Check with your Jack to see if there is play in the tranny mount if it moves up or down at all if so get some washers or make some spacers for the bolt that goes through k member.....lmk how it goes my foxy lady still calling ur name whenever ur ready Bro
Old 10-17-2011, 02:23 PM
Alex2210's Avatar
ur gonna need more boost for me bro lol jk
Old 10-17-2011, 05:37 PM
jmd
jmd's Avatar
The ES is known to be taller than a stock mount when the spacer plate is used. It might be taller without that plate.
Check the torque arm bushing for breakage since the noise is continuing.
Old 10-18-2011, 02:57 PM
Internet Mechanic
BlackScreaminMachine's Avatar
Ever since going to a ES bushing and a TQ arm relocation kit, I have had a vibration. People mentioned it with the PRE load plate, or the bumps, at this point I am putting the rubber back in since the stress is off the tail shaft anyways and the front is Rubber.
I personally never noticed a height difference but then again I was not looking that hard.
Old 10-20-2011, 10:08 AM
strokerrace's Avatar
If the shifters sittin lower that would mean that the bushing you replaced it with is taller than the energy suspension one.... So u dont need a spacer, maybe u need to take out a spacer...
Old 10-20-2011, 10:10 AM
Wait nevermind disregard that. Too early and was thinking about a different mounting setup!!!
Quick Reply: transmission mount (m6) help!
