4l60e rebuild woes
Old 10-20-2011, 08:25 PM
spikely23's Avatar
Default 4l60e rebuild woes
In the midst of upgrading my stock 4l60e I have ran into a few possible problems.
1. The low and reverse roller clutch makes a squealing sound when rotating. Other than that it looks fine and operates correctly.
2. After installing a new wide 2-4 band (and also a new reverse input drum) the output shaft is very hard to rotate in reverse by hand. It gets considerably harder after installing the corvette 2nd servo and the factory 4th servo. Finally, its damn near impossible to turn with the corvette 2nd servo and the superior 4th billet servo. Also it appear that the snap ring never fully seats when using the aftermarket billet servo. Also the I've been installing the transgo HD2 kit.
Has anybody had similiar problems?
Thanks in advance,
Old 10-21-2011, 10:22 AM
LS1Tech Sponsor
performabuilt's Avatar
Well there will be some drag but you may need to use a different pin length . As for the sweeling on the roller clutch that is normal.
On the servo are you shure you are installing all correctly maybe post a picture of how you have it all laid out.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 10-21-2011, 01:14 PM
Gilbert@Ace Racing's Avatar
How many spacers are you using on the servo?
Try going with one or none.
g
Old 10-21-2011, 03:21 PM
spikely23's Avatar
I'll try and get pictures as soon as possible the results I posted about were without any spacers. With one or two spacers I don't even think I could get the cover seated properly.
Old 10-22-2011, 09:29 AM
If you can install one spacer, and still be able to push the cover in about an 1/8" - 1/4" then run it. If not, then do not use a spacer. That itself couldbe the reason your band is dragging.
g
Old 10-24-2011, 07:56 AM
spikely23's Avatar
Thanks for the replies, I haven't gotten a chance to mess the transmission yet, but I'll see if the suggestions work.
Old 12-21-2011, 03:35 PM
greywolf40's Avatar
I made a decent little 4l60e rebuild video here:
http://www.youtube.com/watch?v=JpmJtuVrdWk
Hope it helps!
