Best ms4 setup?
Best ms4 setup?
Hey guys I have a 02 z28 6spd with a ms4, ported tb, ls6 heads, ls6 intake, lt straight pipe, stock rear gears , stock fuel injectors, it currently makes 435 hp 416 tq, my question is what else can I do to get more out of this cam?
FAST intake/tb setup
Chrs1313 ram air
1 7/8 headers
410s or lower
Set of heads, compression will play a the roll in how cams that size perform
That's a start
If you didn't want to spend money or go max effort, you picked the wrong cam. Max effort cams require max effort everything to work the way they should.
A **** ton.
Chrs1313 ram air
1 7/8 headers
410s or lower
That's a start
Chrs1313 ram air
1 7/8 headers
410s or lower
That's a start
You bought their cam I would definately call TSP and take a look at their PRC 215s. They can custom build you a set that will allow for max compression at a safe pvc.
